What speakers for Onkyo Amp?
Username: Tigerswinbig
Louisville, Ky Usa
I need help. I am looking to pair some speakers with my Onkyo home theatre amp. The speakers would be for combination home theatre and audio listening. I will probably use them more for home audio listening than movies if this helps.
Can anyone recommend a pair of bookshelf speakers and sub? The room is vaulted, approx dimensions are 15 foot ceiling and 18x20 room size. The speakers would sit on a shelf with approx 8 inches clearance on the sides and back. Any help you can give is appreciated!
Price range is $350 for pair and $350 for sub.
Username: Edster922
Post Number: 3677
Ascend 170SE, ascendacoustics.com plus Hsu STF-1 will fit your budget precisely.
For a little extra bass you could also look at the STF-2, at hsuresearch.com they often have them refurbed for $350 shipped.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7754
Forgo the sub and buy these: https://www.ecoustics.com/electronics/products/reviews/186180.html
Username: Twebbz
Ann Arbor, Michigan USA
Post Number: 364
What kind of music do you listen to?
Username: Twebbz
Post Number: 365
These Energy C-3s have been discontinued but there are still some around at a discount.
http://brandnamez.com/merchant.ihtml?pid=10734&lastcatid=155&step=4&AffNo=446581 33
B&W ASW 300 Sub
http://www.bwspeakers.com/index.cfm/fuseaction/products.models/Label/Model%20ASW %20300
