A low tuned box is louder by ear?
Username: Jprix82
Post Number: 282
Is a low tuned box louder by ear? - And Best way to face subs in a suv up toward the roof or back toward the hatch?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11363
typically, a box tuned to just below the sympathetic frequency of the cabin would be the loudest, though it would sound a bit boomy since tuning frequency would be around 50Hz.
Tuning just above the Fs of the driver is done more for low bass and musicality as opposed to SPL.
tune low for SQ. tune higher for SPL.
for positioning it varies. try downfiring. That often works out very well.
Username: Jprix82
Post Number: 283
how many inches between the subs and the floor if i downfire?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11366
'bout 6" is good.
Username: Jprix82
Post Number: 284
Glasswolf,whats your opionion on the ABC box
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11369
depends what you want it for.
I think it's SPL oriented, and I'm not an SPL competitor.
Username: Jprix82
Post Number: 285
i kinda want loud SQL. how does it compare against a ported box?
Username: Talon_es93
hey i need some help.. i'm tryin to set up a hard hittin system i want the best in my town but idk what to get between type-x.. audiobahn immortal... L7s... kicker comp VX... W6v2s...thunder 9500s.. or fosgate T2s..them i need to know what amp i would need for 2 12s of w/e i get... keep in mind i'm throwin it in a 93 talon
