New member Username: TigerswinbigLouisville, Ky Usa Post Number: 1 Registered: Mar-06 | I need help. I am looking to pair some speakers with my Onkyo home theatre amp. The speakers would be for combination home theatre and audio listening. I will probably use them more for home audio listening than movies if this helps. Can anyone recommend a pair of bookshelf speakers and sub? The room is vaulted, approx dimensions are 15 foot ceiling and 18x20 room size. The speakers would sit on a shelf with approx 8 inches clearance on the sides and back. Any help you can give is appreciated! Price range is $350 for pair and $350 for sub. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3677 Registered: Mar-05 | Ascend 170SE, ascendacoustics.com plus Hsu STF-1 will fit your budget precisely. For a little extra bass you could also look at the STF-2, at hsuresearch.com they often have them refurbed for $350 shipped. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7754 Registered: May-04 | Forgo the sub and buy these: https://www.ecoustics.com/electronics/products/reviews/186180.html |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 364 Registered: Apr-04 | What kind of music do you listen to? |
Silver Member Username: TwebbzAnn Arbor, Michigan USA Post Number: 365 Registered: Apr-04 | These Energy C-3s have been discontinued but there are still some around at a discount. B&W ASW 300 Sub |
