1. Press the Open button on your remote control to >open the drive tray >2. Press the 2403960 button on your remote control >3. Press the Enter button on your remote control to >change the region to 1 >for >region 1, 2 for region 2, and so on, or 9 for >multi-region playback >4. Press the Open button on your remote control to >close the drive tray >5. Power off the DVD player >6. Power on the DVD player
guillaume
it doesn't work ! can you be more precise ?
Thank
GT
Woodster
Does anyone have the the code to make my Toshiba RDXS24 dvd recorder region free? Many thanks
