Good match...?
Username: Killer44
Ontario Canada
Post Number: 414
im gunna get this amp to run my kicker comp cvr 10's...is it a good amp for them,,,and is it a good amp in general? thanx in advance
Username: Rovin
Trinidad & T...
Post Number: 6223
u 4got 2 post which amp .....
Los Angeles, CA USA
Post Number: 2907
get what amp???????
Username: James1115
Ct
Post Number: 5351
I have done that before it sucks when you have a brain f@rt:-)
Username: Killer44
Ontario Canada
Post Number: 415
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1458739/vpcsid/0 /SFV/30046
sorry heres the site...must be a sign thats its time to get some sleep...school is gunna be rough tomorow lol...
Username: James1115
Ct
Post Number: 5355
those specs are wrong! it is 600 watts peak not rms it is 300 watts rms strappable to 600. http://directed.com/coms.asp
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2330
the orion 600d is 600wrms.
the new HCCA-d600 is 300wrms.
Username: Rovin
Trinidad & T...
Post Number: 6230
from Orion's last yr webpage which i have saved on my pc >>>>>>>
AMPLIFIERS - CLASS D MONO
ORION 2500D
ORION 1200D
ORION 600D
Features | Specifications
Whether it's more power or more channels Orion's 2003 amplifier lineup delivers. The new 2500D delivers an astounding 2500 watts into 1 ohm -- and those are real, 13.8V continuous watts, not the "if lightning strikes" watts some companies claim. Whether your goal is an SPL world record, or you just want the meanest, hardest hitting system in town, these three new class D models will get the job done. Extreme power, extreme efficiency, and extreme construction details like massive paralleled internal busses and a directed internal air flow cooling design characterize these monster amps that proudly advance Orion's legacy.
Class D mono block model features:
* Selectable 12/24 dB/octave variable low-pass filter
* Intelli Q bass optimization circuit and remote gain option
* Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
* Copy/Master feature supports gain and crossover adjustment matching in multiple amp
* Allows external bridging of two matched gain amplifiers (models 600D and 1200D only)
* Switchable phase invert function
* Heavy gauge direct-wire high current satin finish power and speaker terminals
Specifications:
Model Number 600D 1200D 2500D
Max Power 600 1200 2500
4 Ohm Rating 250 x 1 425 x 1 1200 x 1
2 Ohm Rating 400 x 1 725 x 1 1700 x 1
1 Ohm Rating 600 x 1 1200 x 1 2500 x 1
...so whats it , WRMS or WATTS MAX ???........
Username: James1115
Ct
Post Number: 5360
interesting!
Username: Killer44
Ontario Canada
Post Number: 417
k well are the specs on these ones correct james...and is good for my subs?
http://www.sonicelectronix.com/item_717.html
http://cgi.ebay.ca/Orion-Amplifier-600D_W0QQitemZ5777033586QQcategoryZ18797QQssP ageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.ca/ORION-600D-600-WATT-Class-D-Amp-NEW-w-Intelli-Bass-05_W0QQite mZ5875877666QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
*and this one is showing wrong specs also rite?
http://cgi.ebay.ca/ORION-600D-1200-WATT-MONO-CLASS-D-CAR-AUDIO-AMPLIFER_W0QQitem Z5873943354QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 2331
the 2003-2005 model orion 600D, 1200D, and 2500D put out 600w+, 1200w+, and 2500w+ RMS...respectivly. (rated at 13.8V)
Post Number: 2332
killer,
all the links you listed above show the correct RMS rating on those amps.
Username: Rovin
Trinidad & T...
Post Number: 6234
Er - so like James L made a blooper there when he said max !? .........
Username: Killer44
Ontario Canada
Post Number: 418
thanx alot marshall so ur saying that this site
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1458739/vpcsid/0 /SFV/30046 has the correct rms ratings as well is was the first one i put @ the begining of thread>
Post Number: 2333
yes...this site does have the correct power ratings for the 2003-2005model orion 600d
Username: B101
Queen City, NC USA
Post Number: 1528
i didnt think it would be this confusing to so many, lol
marshall is correct...
orion
d in front number = MAX rating
d after number = RMS rating
d1200=600rms
600d=600rms
Username: James1115
Ct
Post Number: 5366
well when you are used to one thing or see one thing it's not as much confusion as it is overlooking. D1200 or 1200D can easily be mistaken for each. I have never owned either to tell you the truth(not a orion fan since they sold to Directed). When all you do is go to the web site to look up spec's which I did the D in front or the D in back can be easily looked over and I am sorry for the mix up guys.
