Tv antenna question
annonymous kirt
i heard if i get a tv antenna i can pick up certain local channels in HD. WHere can i pick up one of these and about how much are they. are there certain brands i should look at?? thanks a bunch
Username: John_s
Columbus, Ohio US
Post Number: 672
annonymous kirt
Posted on Wednesday, February 01, 2006 - 08:12 pm:
What TV model do you have?
Username: Fyi
Dallas, Texas
Post Number: 596
I like Winegard, but there is Channel Master and others. Even Radio Shack offers a decent VHF/UHF antenna. There's nothing special about it. It's the same old antenna that's been on roof tops for more than 50 years.
http://www.solidsignal.com/antennas/?xfermeth=directg&gclid=CLD7kZvr-IICFThnOAod wleNrA
http://www.winegard.com/offair/offairmain.htm
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=vhf%20antenna
annonymous kirt
i have the panasonic pt-50lcx64. will any antenna work for any tv or do i have to find a specific one? also i see VHF/UHF and VHF/UHF/HD antennas. does having the HD one matter or will i be able to pick up HD channels with just a VHF/UHF one? thanks for the help
Username: Fyi
Dallas, Texas
Post Number: 597
There are no specific antennas made for a certain tv?
I'll repeat!
There's nothing special about it."
It's the same old antenna...
Don't pay more for one that says HD. It's a rip!
Go to www.antennaweb.org
Put in your zip code and see how far you are from your local digital stations. By an appropriate sized antenna for your distance from the towers.
Username: Videobruce
Buffalo , NY
Post Number: 106
Better off with 2150. No 3rd grade color charts;
http://www.2150.com/broadcast/default.asp
Username: John_s
Columbus, Ohio US
Post Number: 813
videobruce, now we have to know our longitude and latitude?
Thanks I'll stay in the 3rd grade.
