New member Username: CadavisAtoka, OK USA Post Number: 4 Registered: Mar-06 | My 30" dish isn't skeable. Will I be able to pull in all the channels on 119 and 110 without the skew. I ask this because my Dish Network dish does have skew. |
Gold Member Username: LklivesPost Number: 1096 Registered: Jan-06 | Sure..my old DTV dish doesn't have skew and is actually simpler to align to the 110 and 119...U will get all the channels.. |
New member Username: CadavisAtoka, OK USA Post Number: 6 Registered: Mar-06 | Great! I have a lot of questions here and there and I thank you for your help. Once I get that bird dog sat finder in the mail...things will be a bit easier. I get on the roof with my cell phone and call my wife in the house and she relays my signal level...she tends to get a little cranky if it takes a while. The dish movement is so touchy. Again, thanks |
Gold Member Username: LklivesPost Number: 1099 Registered: Jan-06 | Basically aim towards Mexico...there are satfinder calculators U can use..shouldn't take more than 15 minutes to get dish aligned.. read this for best DSS sites for manual,guides and files..great forums and help...will help U with Dish pointing topics and others..also in this link are some satellite finders/calculators.. https://www.ecoustics.com/electronics/forum/home-video/198399.html |
