New member Username: Cminus909Post Number: 2 Registered: Aug-04 | Wat is the best way to wire 3 10" 4 ohm Alpine Type Rs (http://www.alpine-usa.com/en/products/product.php?model=SWR-1042D) with a Avionixx 2400 Mono amp (http://www.avionixx.com/nxd.html) would i b able to run it at 1ohm and get 1200RMS? |
Gold Member Username: RovinTrinidad & T... Post Number: 6012 Registered: Jul-05 | bets way to wire 3 (4ohms dvc) subs would be ur amp specs RMS Power @ 4 ohm550 watts mono/0.1% THD RMS Power @ 2 ohm950 watts mono/0.5% THD RMS Power @ 1 ohm1200 watts mono/0.5% THD id' guesstimate with a 2.67load amp each sub would be getting around 280wrms roughly each sub is rated 500wrms so that would be underpowering i'd get a 2000wrms @ 1ohm amp ... BTW - why didn't u choose like 2 750wrms 12" subs with a 1500wrms amp instead ? ...... |
Gold Member Username: RovinTrinidad & T... Post Number: 6013 Registered: Jul-05 | "i'd get a 2000wrms @ 1ohm amp ..." meant to type i'd get a 2000wrms @ 2ohms amp ... 3 sub especially DVC subs really makes it hard to find a suitable amp ...... |
New member Username: Cminus909Post Number: 3 Registered: Aug-04 | I havnt got the subs yet?? Wat should i go with i already have the Avionixx 2400... Wat subs would i be able to run at 1 OHM and get 1200 RMS out of the amp??? |
Gold Member Username: RovinTrinidad & T... Post Number: 6025 Registered: Jul-05 | 2 12" 1242D alpine type R subs ........ |
New member Username: Cminus909Post Number: 4 Registered: Aug-04 | Do you think i would get a better sounding bass out of 2 10" 1242D alpine Type R's?? How many ohms should i run the 12s at?? ...thanks |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 139 Registered: Dec-05 | if you get the 12's then 600w each is good, ask to rovin |
Gold Member Username: RovinTrinidad & T... Post Number: 6046 Registered: Jul-05 | Yep get 12s - mine easily handle 600wrms (on another amp i tested on em) & they really slam ! even though they r in 3" pvc port boxes ... https://www.ecoustics.com/electronics/forum/car-audio/189456.html |
New member Username: Cminus909Post Number: 5 Registered: Aug-04 | In order to run my amp at 1 ohm wat ohm subs would i need???? |
