New member Username: Tim375Post Number: 1 Registered: Mar-06 | I have super dish I am still subscribed to D.N. I am using pansat 2700a with 143 bin autoroll. I didn't change the original switch from D.N. When I programmed pansat, All I am getting are channels from 110. I am not getting anything from 119 or 121. LK or some body please help me out How to get channels from 119 ,121?. Do I need to change the swich for that?. P.S. : When I programmed I set default key on. Will that be enough or Do I need to enter D.N. keys? Thank you in advance, Tim. |
Silver Member Username: LeewKetchikan, ALASKA Post Number: 222 Registered: Jan-06 | LNB ,SWITCH |
New member Username: Tim375Post Number: 2 Registered: Mar-06 | Do you want me to add the switch I got with pansat2700a?. |
Gold Member Username: LklivesPost Number: 1231 Registered: Jan-06 | How many LNB's on that dish ...U should have 3, and yes all 3 need to be connected aligned carefully at the 110-119-121, then cabled to a disque switch (remove DN's switch), and then a cable to your receiver from the switch....Then U must configure your receiver antenna and LNB settings...then scan the 3 satellites, upload the bin, set the default keys, watch TV..scan is best without the disque connected and cabled direcly from LNB to receiver.. These things are all FTA basic 101!!!need to read, so U can learn...cannot learn anything by just asking questions here.. |
Silver Member Username: LeewKetchikan, ALASKA Post Number: 223 Registered: Jan-06 | I meaned = check setting . |
Silver Member Username: LeewKetchikan, ALASKA Post Number: 224 Registered: Jan-06 | If you want, I can send you pansat bible,it's for 2500 but you can use it for yours too. Just PM your E-Mail, |
New member Username: Tim375Post Number: 3 Registered: Mar-06 | where can I read FTA basic 101?. |
Silver Member Username: LeewKetchikan, ALASKA Post Number: 225 Registered: Jan-06 | so, you don't want my bible .Then you can start reading from "A" to "Z", or use GOOGLE.c om |
New member Username: Tim375Post Number: 4 Registered: Mar-06 | I want that. Email addr is mcpetdog@yahoo.com |
