Hello everyone..I did a search in the forum but could not find exactly what I was looking for so I figured I would ask -
- I have 2 Pansat 2700 receivers - 2 satellitle dishes, one has 2 LNB's for 110&119 and the other dish has one LNB for 61.5
One of the receivers is already hooked up and working. How do I set up the other receiver? I only want 110 & 119 on the other receiver. I was told I need another Switch for my new receiver...if this is true, how does everything get hooked up? Thanks in advance, I appreciate your help.
U need 2 disque switches...and MUST have 2 outputs on each LNB (110 and 119 LNB's)...substitute the disque switches for the sw21 switches in this diagram..thanks to M Lee for the diagram
Thanks...I tried the tinfoil idea and it worked like a charm! Horray!
Seriously though LK thanks for clearin it up - would it be possible to just use a a splitter instead of getting another switch?? I have been told that this would work too but am a little weary about the idea.
