Username: Luke5513
Post Number: 38
I was looking at the diamond 6.5 component set for the front. they have a set of last years model 5 1/4 for $200. will it make a differance?
Nate So
no posts... Bump
I have the top 6
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1167
i've read that the older models have much larger magnets and baskets, which can make them hard to install. you might wanna check on that first.
Username: Bobok7787
Post Number: 11
what exactly are you asking? the difference of SQ between 5 1/4 to 6 1/2 or....?
