Anonymous | Does anybody know why it does this? I'll just be watching TV, nowhere near the remote control, and all of a sudden the black box in the upper right hand corner will appear with the name and number of the channel I'm watching. Sometimes it happens once a day, sometimes it happens every five minutes or so! That's when it gets annoying... I don't want to turn off the messages completely because then they don't show up at all when I'm surfing channels, but once I pick a channel I don't need to see it anymore! Thanks for your help! |
Bronze Member Username: Paul_tPost Number: 85 Registered: Dec-03 | I'm betting the TV Guide is kicking on and updating.... Last night my wife called me at work and said the remote was changing channels by itself, when I told her to take the remotes out of the room and it still did it I knew what it was.. Just had her move the IR Blaster away from the cable box and it stopped.. |
Anonymous | Hi! Thanks so much for responding. The thing is, though, that I don't have a cable box, and therefore am not using the IR Blaster. The Guide seems to work fine without it, except for this one little glitch. Any other ideas? Thanks again! |
fx Unregistered guest | The batteries in your remote are weak. xvxvxvx |
plinko Unregistered guest | Go to setup screen and disable "status messages" option |
Anonymous | Thanks for the responses, guys. Unfortunately fx, I replaced the batteries and it's still doing it. plinko, as I said in my first post, I'd rather not do that because then they don't show up at all, even when I'm surfing. I think I'm going to have to call the maintenance number in the instruction manual. Thanks anyway! |
New member Username: Nelson41Post Number: 1 Registered: Feb-06 | have recently purchased a Panasonic DMR-HE50 DVD recorder and would like to make it multi Region so that I can play my Region 1 DVDs. Could some one tell me how to do this.and is possible to up grade the hrad drive to 160g? Please advise to email nelson41@iprimus.com.au |
