| im currently looking at this system for full intergration with my pc studio.... but have been stumped.. it first i couldnt find any mention as to whether or not i could play music from my pc to the lissa then i find this. " In fact, the only obvious downers at this stage are that you can't copy music from the LISSA to your PC (or vice-versa)" at http://www.t3.co.uk/rev_print.asp?rev_id=1594 that would indicate that there is no musical transfre ability between the lissa and the pc. so i ask whats the point? just so the pc can work as a desktop remotecontrol? |
| you can buy using the second version of the lissa softwrae - but its only available currently in Japan, if someone can get me a copy ill have one!!! do a search on google for lissa mp3. Something odd though is that in XP you can play audio via firewire through the lissa - although the software ownt work on XP, ive had to make my xp machine 2000 dual boot |
| I'm also looking for the second version of control software for the LISSA. Let me know if you have it. Can version 2 (PCLK-LSA2) actually record wav files from yor PC to the LISSA MD? Denis |
| Let me know if there's any news about the pclk-lsa2 |
| I've just gotten PCLK-LSA2. Version 2 of the LISSA software |
Denis James | Nicolas at Hifissimo is going to post Version 2 here: http://www.hifissimo.com/store/loadpage.cgi?user_id=2460&file=test_lissa.html go to bottom of page "Téléchargement du logiciel de la Sony Lissa pour PC" Click on that! That should be where he puts version 2 for download. It should be there shortly. |
Denis James | Go here for Version 2 http://download.hifissimo.com/sonylissa.exe (11.3MB Download) |
