Where can I get a Box built Metro in Atlanta
Username: Black013
Post Number: 53
I need a box built for 2 L7 anybody in GA build boxes or know a good stereo shop that does
Username: Eeater
Post Number: 43
make your own man.
What sizes are you looking at height,with,depth?
Username: Eeater
Post Number: 44
This sit is really cool
http://www.accelerator-pedal.com/l-ported-box.htm
Username: Eeater
Post Number: 45
This site is really cool
Username: Black013
Post Number: 54
I not much of a craftsman I never did well in shop class I dont know the sizes thats why I need one built
Username: Eeater
Post Number: 46
almost forgot...
http://www.bcae1.com/spboxnew2.htm
Username: Eeater
Post Number: 47
that site tells you how long to cut each board!
Username: Black013
Post Number: 55
I dont need box specs kicker sent me those I just need it built
Username: Eeater
Post Number: 48
But 2 sheets of MDF Medium Desity Fiberboard. 3/4" its soooooo easy and cheaper.
Username: Eeater
Post Number: 49
were do you live?
Username: Eeater
Post Number: 50
If you want I will build you one for $120.00+ship.
Username: Black013
Post Number: 56
Opps you have to put the specs in and than it tells you how to cut ohh thanks but what about port tuning ?
Username: Black013
Post Number: 57
Atlanta
Username: Homegrowncam
Watauga, TX United States
Post Number: 209
He wouldnt need 2 sheets of mdf. Possibly half of one for 2 l7s. I am sure you have a circuit city. I know they do build boxes.
Username: Eeater
Post Number: 53
hes a first timer he will need 2 sheets
Username: Eeater
Post Number: 54
give them each 40-60 square inches of port.a piece
Username: Eeater
Post Number: 55
if you give me your demensions i can CAD you up something real quick ~ 30 min
Username: Black013
Post Number: 58
E thanks for having confidence in me but I paid to much for these speakers to mess up now so I think I will stick with circuit city any 1 know thier rate and can they do it same day?
Username: Eeater
Post Number: 57
what are you puting them in?
Username: Black013
Post Number: 59
cutlass
Username: Eeater
Post Number: 58
what size L7's?
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2188
Cartunes in marrietta. Jeff Smith used to work there, but moved to his own shop (google). DO NOT go down the street to The Source Car Audio. They suck. Any Hi FI Buys (Northlake, etc). But all these guys will rob you. If you have the loot to spend, cool. But you would spend 1/2 the price doing it yourself. Home Depot actually cuts the wood into dimension for you. You would only need to put it together. And they could still help you out there. Plus you could review this: http://www.sounddomain.com/ride/261051
