Splitting hd signal
Username: Ekbsrk
I have two hd boxes split from one cable line. I used to get every channel when i had only one box. But when i added the second box, i only get every channel on 1 of the boxes. are there any settings or resets that i can do to fix this?
fx
Yes, you need to smash the box you purchased off E-Bay and eat all the pieces. You will then learn a lesson not soon forgotton.
xvxvxvx
First off i didnt get the box off ebay. they are both from time warner cable you dickweed. but thanks for the smart answer. why dont you go get hit by a bus becuase the world doesnt need ppl like you.
