Toshiba SD K750 region free codes
Username: Lindsesom
Goleta, CA United States
1. Press the Open button on your remote control to
>open the drive tray
>2. Press the 2403960 button on your remote control
>3. Press the Enter button on your remote control to
>change the region to 1
>for
>region 1, 2 for region 2, and so on, or 9 for
>multi-region playback
>4. Press the Open button on your remote control to
>close the drive tray
>5. Power off the DVD player
>6. Power on the DVD player
guillaume
it doesn't work !
can you be more precise ?
Thank
GT
Woodster
Does anyone have the the code to make my Toshiba RDXS24 dvd recorder region free? Many thanks
