Help!!
Username: Shamacala
hi!! i have recently purchased a toshiba 42wlt58 tv & a toshiba sd350e dvd...i wish to link up to a 5:1 surround speaker system...is this possible??...what would be the best purchase??...& finally what way would i connect the whole system up to receive 5:1 from both tv/dvd?? thaks in anticipation...
Username: Eld
Texas
Post Number: 34
Martin,
You will need a 5.1 receiver or pre/amp combination to feed your DvD and cable/satellite signals.
A few questions for us to better help you out:
How much do you want to spend for receiver and speakers?
How large is your room?
How much time do you plan to spend listening to music on the system, do you prefer multi-channel or stereo mode, and what is your music preferences?
Username: Shamacala
hi elderion... thanx for your reply!!...i budgeted to spend £200 max - room is standard 14'x12' - listening to music is not really my forte - i only wish to listen to 5:1 surround sound from tv/dvd soundtrax
Username: Eld
Texas
Post Number: 37
Martin,
I'm not too famaliar with Great Britian market, but at that price range, your best bet would be a Home Theater In a Box (HTIBs) option.
I recommend you look into the following systems and see which one you would like the best:
Panasonic SC-HT930
Panasonic SC-HT700
Sony DAV-FX10
JVC TH-C6
Onkyo HT S580
Yamaha YHT-160
Pioneer HTP-3600
All should do pretty well as 5.1 HT setup for you.
Happy shopping!
Eld.
