Avalanche Tuning
Username: Clacla100
Tallahassee, Fl US
Post Number: 77
I got some box plans from a box calculator. It said it was tuned to 31 hz, but when i went to buy the terminal cup they guy at the store told me the design was wrong and it would tune it at a higher hz. Here is the specs can anyone tell me what this will make the frequency tuned at?
Net Volume: 2.25 cubic feet
Port Width: 3.75 inches
Port Area: 46.875 square inches
Port Length: 52.75 inches
Thanks
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1907
if its a slot port then its tuned lower than 31 hz. if its not a slot port then its 31 hz.
Username: Clacla100
Tallahassee, Fl US
Post Number: 78
its a slot port and its 12.5 inches tall. how much lower do you think its tuned to?
thanks
Username: Clacla100
Tallahassee, Fl US
Post Number: 79
bump
Post Number: 1926
appx tuning is 30.5 hz
