Ikesound.com ?
Username: Killer44
Ontario Canada
Post Number: 386
has neone bought nething from this site?
im planning on buying this amp http://www.ikesound.com/product-product_id/2426
to run my kicker cvr's (10dvc4ohm)
should i build a box like this for both of them
http://cgi.ebay.ca/KICKER-05TCVR10-D4-CAR-AUDIO-TRUCK-SUB-BOX-W-CVR-10_W0QQitemZ 5865184731QQcategoryZ39772QQrdZ1QQcmdZViewItem
or i heard that it was better to keep them in sealed enclosures , there going in a 1987 reg cab s10, which type of box would be louder im lookin for spl....thanx in advance
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1706
they have very good prices and i havnt heard of many people having problems with ordering from there , so i say go for it
Username: James1115
Ct
Post Number: 5136
well if you can fit a ported enclosure it will deff be louder then a sealed box. That amp will work for you if you wire them parr/parr to 1ohm. I am not a big fan of buying refurbed equipment but if it works I guess it's worth the price.
Username: Mystre
Pemberville, Ohio USA
Post Number: 24
I purchased from them and I say go for it, I was very satisfied. Except with MY decision to go with AudioBahn.
Username: Killer44
Ontario Canada
Post Number: 388
thanx casey...ne one have ne thoughts on waht i should do for the sub box?
Username: Killer44
Ontario Canada
Post Number: 389
so its not true that a ported box will sound bad in the single cab truck, i was possitive that i heard it was best to go with seal for single cab trucks, but i do know that ported is louder....ne one else know?
Post Number: 1708
with a single cab truck , go sealed , trust me dont mess with ported with that amount of room
Post Number: 1709
its a single cab truck , the subs are just right there behind you , it will get loud i promise you
Username: Killer44
Ontario Canada
Post Number: 390
james i was jsut going to wire them both to 2 ohms in seperate enclosures, then wiere them to the amp, im pretty sure this will present the amp with a 1 ohm load, am i correct?
Username: Killer44
Ontario Canada
Post Number: 391
thanx alot cassey will the way i said i was going to wire them in my last post work?
Post Number: 1724
yep 2 dvc 4 ohm subs will wire down to 1 ohm so you're fine
Username: Killer44
Ontario Canada
Post Number: 392
thanx
