Does Infocus 4800 monitor out work with bulb out?
Username: Mjuenem
I have a Infocus 4800 with the bulb out and displaying the triple flashing red LED. The fan is running and the green LED shows correct software load.
Is monitor-out supposed to work in this situation so you can use the menu to check bulb hours or firmware level and other information to see if the unit is worth buying a new bulb for? I can't seem to get any display through monitor out - then again maybe it is not supposed to work in a bulb-out situation. I just thought that it might to help facilitate troubleshooting. I can't find an answer to this in the documentation. Anybody out there know?
Thanks
Mark
