How does this look?
Username: Adam_s
Post Number: 10
I am thinking about getting this sub/amp combo. let me know what u think and if I could do better for the money. ALPINE SWR-1521D 15" SUBWOOFER and a profile ap1200 this will cost me around 350 so if anyone has other suggestions please feel free to shout them out. thanks
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1699
im not so sure about the profile amp but the 15'' r will get very loud if powered right and in a good ported box
Post Number: 1700
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5739
how much are u paying for the type R???
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1912
the sub is a good budget sub. i would go with a different amp however.
Username: Adam_s
Post Number: 11
On ebay i can get it for around 200
Username: Adam_s
Post Number: 12
what amp would you suggest??
Post Number: 5741
Is there a store where u can listen to a Kicker CVR and a Type R???
Because personally i dont really like the way the R's sound, i much prefer a CVR
Username: Adam_s
Post Number: 13
I have never listened to the kicker. but i have listened to the type r in the store and my friend used to have one so i heard it in his car as well. but what would you think would b a good budget amp for around 150 or so??
Post Number: 1703
maybe that audiobahn amp ..its 800 watts at @ 2 ohm i believe
Username: Adam_s
Post Number: 14
alright...thanks for the amp suggestion
Post Number: 1704
im sure of the exact name , but you'll be able to find it pretty easily probably
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1060
i have a 15 Type R a while ago powered by just a JL 500/1 and it was nice, sounded good and was pretty loud. went from that to a 13W7 (and another 500/1), lol, that kinda makes everything sound bad.
Post Number: 1710
if you have the money , id say get the new kicker zx 750.1 amp when they come
