600 rms
harold p
whats the cheapest amp i can get that puts out around 600 rms
i want it realy cheap
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1324
Audiobahn A8000T. $150 MAX! Does 800W RMS. I know it's over in the power you want, but it delivers, and you'll have some headroom.
Username: Rovin
Trinidad & T...
Post Number: 5699
Yep ^^^ ! .....
harold p
oh is that at 2 ohm or 4 ohm cuz i need one thats 600 rms at 4 ohm
thx
Wellsburg, WV USA
Post Number: 1326
It will put out 400W RMS at 4 ohms and 800W RMS at 2 ohms.
You're not going to get an amp cheap that does an honest 600W RMS at 4 ohms.
