New member Username: BasiccablePost Number: 1 Registered: Feb-06 | Hi I have 1 12" Alpine type-R dual 2@hm sub in a ported box and I need a new amp as mine is dead. I've rounded it down to three amps and was hopeing to get some of your guys opinions on which one of these would be best Alpine MRP-M650 (400 Watts at 4ohm) Orion 600D (600 Watts at 1ohm) PHOENIX GOLD X600.1 (600 Watts at 1 or 4ohm) I've had good luck with all three brands in the past the only one I'm really worried about is the Orion because I would be running it at 1ohm and I'm worried about heat. What one of these would you guys get? |
Silver Member Username: GoatinU.S.A Post Number: 324 Registered: Jan-06 | Orion 600D (600 Watts at 1ohm) |
New member Username: BasiccablePost Number: 2 Registered: Feb-06 | Anyone know how much of a issue heat is at 1ohm on the Orion? |
Gold Member Username: B101Queen City, NC USA Post Number: 1269 Registered: Sep-05 | get the Orion, dont worry about the heat. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5725 Registered: Jul-05 | Is that a phoenix gold Xenon, if so get that |
New member Username: WafflesdosPost Number: 3 Registered: Feb-06 | hey guys, I hooked up a L5 solo baric with the coils in series to a rockford 700s and it was booming for a day until I got the burning smell fron the speaker. How can this be? the amp only pushes 350 watts @ 4ohms and the speaker should be able to handle 750 continuos and 1500 pmpo. I bridged tha amp, any sug? |
New member Username: BasiccablePost Number: 3 Registered: Feb-06 | yes its a Xenon Series amp |
New member Username: WafflesdosPost Number: 4 Registered: Feb-06 | The voice coils are ok, they check 2.5 ohms, should I hook them back up and lower the gain of the amp? |
Gold Member Username: RovinTrinidad & T... Post Number: 5712 Registered: Jul-05 | Brad - i'd also pick the Orion ......... |
New member Username: BasiccablePost Number: 4 Registered: Feb-06 | Is there any other amps you'd recommend in this price range? There isn't a lot of selection localy(I live In ND) so my knowledge of other brands is limited. |
New member Username: BasiccablePost Number: 5 Registered: Feb-06 | Sorry I'm looking for a class D mono amp that pushes at least 400 watts at 4ohm or is 1ohm stable(Meaning can run that way during a real hot summer day) |
Silver Member Username: JbumpNebraska City, Nebraska USA Post Number: 102 Registered: Dec-05 | What about Hifonics, http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=2634 any advice on that? |
Bronze Member Username: ErgodynePost Number: 26 Registered: Feb-06 | you get a lot of versatility with that PG. So if you want to get some different woofers Ie a single 10W7 that has a 3 ohm load you could still run it at it's RMS with headroom, as where with the other amps you couldn't. |
Silver Member Username: FandimReno, Nevada United State... Post Number: 723 Registered: Jun-05 | I'd definately recomend the PG Xenon. |
