Bronze Member Username: AfroopuffPost Number: 51 Registered: Jan-06 | The memphis car audio site gives specs for what they think best enclosures are, and it says for vented, there are MIN and OPT specs... it says that MIn is for minumum airspace and greater power handeling, while OPT is for optimum airspace and less power handeling...i took that as in the MIN is more for SQ and OPT is for more power is that correct? |
Gold Member Username: TdbdadrummerWellsburg, WV USA Post Number: 1345 Registered: Aug-05 | Are they sealed or ported enclosures, when they're refferring to airspace? |
Bronze Member Username: AfroopuffPost Number: 52 Registered: Jan-06 | ported and also, im looking at the specs, it says 9.5x3x19, how is that possible for 2 drivers, that is so small, and they are 10 inch subs....it says something about all airspace recomondation are internal and include port/driver displacement, but still 9.5 inches on a 10 inch driver. how is this possible? |
Silver Member Username: Safe_crackerChicago, IL US Post Number: 238 Registered: Jan-06 | 9.5 is actual mounting hole for the driver. The 10" dia is actually the whole sub including surround, basket, etc. How about a site link to check it out? Polo.. |
Bronze Member Username: AfroopuffPost Number: 54 Registered: Jan-06 | http://www.memphiscaraudio.com/LiveImages/114/30/DocumentURL.pdf that link should work, otherwise try http://www.memphiscaraudio.com/support/ and its like the 5th link down labeled "eclosure recomondations" |
Bronze Member Username: AfroopuffPost Number: 55 Registered: Jan-06 | what about the 3 inches it says, a driver is more than 3 inches isnt it? and 19 inches? 2 10 inch drivers next to each other? it just doesnt sound right |
