Whats a decent cheap amp 300W x 1 @ 2 Ohms?
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 65
The sub is a MTX 12" that takes 300 RMS in about 1 cube sealed. The car is a 2004 WRX STi with kappa components and eclipse HU.
My friend has absolutely no money to spend on an amp but he already has everything else needed to hook up the sub. Can he get something half decent for under $100 on ebay?
so his sub is dual 4 0hm get arefurbished viper
Username: Juliob
Santo DomingoDominican Re...
Post Number: 105
BUDGET BRAND= PROFILE FROM BAJA CALIFORNIA. THEY ARE VERY CHEAP AT MILLIONDOLLARBUY.XOM IF I'M NOT CORRECT? ASK TO OPTIDRIVEN
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5571
close 400@ 2 ohms and only $79
http://ikesound.com/product-product_id/2119
Username: Lewass
Post Number: 68
sub is 4 Ohm SVC
Post Number: 5602
ok, i was just going by the title, my bad
he is not gonna find anything decent that will put out 300x1 @ 4 ohms, can he raise his budget a bit
http://cgi.ebay.com/Audiobahn-A8000T-Intake-Mono-Amplifier_W0QQitemZ5866492365QQ categoryZ48597QQrdZ1QQcmdZViewItem
Username: Lewass
Post Number: 69
Final impedence is 2 ohms, I need something that does 300 x 1 @ 2 ohms. Title is right.
Username: Stiflyby
Birmingham, MI U.S.A
looking to spend $100 bucks or so...as long as the amp performs decent..
anybody know of any good ways to attach the amp and sub without screwing them into the carpet? I was thinking really strong tape...any idea, thanks
-total sound newb
Username: James1115
Ct
Post Number: 5114
TAPE? lol
Username: Stiflyby
well, whatever it takes to not have to screw something in...I figured there would be some really strong tape that could do the job for a box that would only weigh maybe 10 lbs
Username: Lewass
Post Number: 72
Oops, my bad, I've been looking at so many DVC subs I wasn't thinking about wiring a SVC.
Sub is MTX MZS1204: 300 RMS, 4 OHM SVC
So my friend needs an amp that is 150 x 2 @ 4 Ohms or 300 x 1 @ 4 Ohms
What is solid amp that will last a while. Used/refurb/new/whatever
Username: James1115
Ct
Post Number: 5119
soundstream reference 300 is a fantastic amp and can be had for under $100 sometimes on ebay.
Username: James1115
Ct
Post Number: 5121
the problem with tape is that amps get hot and the glue will melt. you will have a big big mess. Depending on the vehicle you have you could find a spot where the amp fits and built a enclosure for it the size of the spot it is in so it doesnt move around. I have to let you know it will be very easy to steal if wanted. Why dont you want ot drill a few small holes? you can never tell they are there through the carpet.
Username: Lewass
Post Number: 75
I keep telling my friend that the tape idea is dumb, because he will have to screw the amp down for sure, so he might as well put a small onobtrusive bracket to hold the sub for all the high speed driving he is going to be doing...
But the sub and box together way less than 10 lbs, so I'm sure there is an alternative to drilling..
Username: James1115
Ct
Post Number: 5124
yeah tape just won't work! you know what might work though velcro the whole bottom plate of the amp and stick it to the carpet. That will prob be his best bet. If you want a seriously GREAT amp that puts out 300watts look into that soundstream:-)
Username: Kaos15th
Post Number: 134
i have a used but in good condition kicker kx350.2 it is 350 watts @4 ohm i am selling it for 80+ shipping which shoud be like 10 dollars.
Username: Juliob
Post Number: 109
check the amp specs, from profile.
Peak Output Power (4 Ohms) 400W x 1
RMS Output Power (4 Ohms) 200W x 1
Peak Output Power (2 Ohms) 700W x 1
RMS Output Power (2 Ohms) 350W x 1
MOSFET Power Supply Yes
Total Harmonic Distortion <0.07%
Signal / Noise Ratio 100 dB
Pre-Amp (RCA) Outputs Yes
Variable Bass Boost at 45Hz 0/6/12 dB (Switch)
12dB/Octave Crossover High Pass/Full/Low Pass) HP/Full (Ch 1 & 2) Full/LP (Ch 3 & 4)
Variable LP Crossover Frequency 50 - 250 Hz
Variable Phase Control 0-180 Degrees
Fuse 40A
Dimensions (2 1/4" H x 9 11/16" D) 13" W
for only 80 bucks milionbuy.com
