Help spider on screen
Username: Pdog
Hey I can't believe nobody has the asnswer. There is a perfect outline of a spider on my screen and it's driving me nuts. It is a panasonic PT-53TW53. Can I take the screen off and just take it out or will it mess up the picture. I'm not a TV mechanic so I don't know. Thanks.
Username: Uhphikap
Post Number: 63
Jim,
Is your TV still under warranty? If so, you should call Panasonic. Actually, either way you may want to call them...if you're not covered under warranty, they may still be able to give you some guidance if you are going to attempt to take the screen off.
Thanks,
Brian Pool
TapeWorks Texas
1-866-827-3489
tapeworksbrian@sbcglobal.net
