Juan Alligator Unregistered guest | At my house, we just finished the room over the garage and are making it a home theater entertainment room. We are planning on buying this[1] tv, but after that it is kind of up in the air. As far as receivers go, we are planning on getting this[2] one, but I learned that can only convert analog to HDMI if the tv can display content at a 480i resolution, and I don't know if the one I choose can. So, boiled down, I have these questions: 1) Is the TV the best choice, with picture quality as the first concern? 2) Will the receiver work with, or would a better one work better? 3) What speakers should I get? 4) Can I plug a computer, an Xbox 360, a comcast cable box, and maybe a dvd player into the reciever and have everything work with sound and only have one connection to the TV? [1] http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=1120 1&catalogId=13051&itemId=94540&catGroupId=14624&surfModel=TH-50PHD8UK&displayTab =R [2] http://reviews.cnet.com/Pioneer_VSX_72TXV/4505-6466_7-31612930.html?tag=sub |
Gold Member Username: Project6Post Number: 5927 Registered: Dec-03 | 1.)The TV is a good choice. There is no such thing as the best when it comes to a lot of goods. The best is subject to the person using the term. 2.)The receiver will work and I believe is a very good receiver. 3.)What is your budget for the speakers? 4.) Yes, all it takes is know-how and by reading all the instruction manuals. |
