I was simply wondering if I needed to connect the fuse, to a fuse block or could i possibly just hook each side of the fuse to the wires and some electrical tape, also whatr happens if I dont use a fuse its just a 35W amp. Also what could it destroy if i didnt have a fuse?
umm i wouldn't tape the wire to the fuse just get an in line fuse holder they are pretty cheap. Beyond that i'm not to knowledgable in this area, but i think you could melt your wire and start a fire/possibly phuck up your cars electrical system without a fuse on your main power wire.
