Is this amp any good to push 2 12" alpine type r's???
Username: Thomas_g
NM
Post Number: 49
Is the lanzar 2000 watt max amp(500watts rms@4ohms\2 channel) enough to push 2 12" type r's?? Im on a tight budget now. Would it sound alright?
Username: Goatin
U.S.A
Post Number: 315
are your R's 2 or 4 ohm?and what is the RMS on the subs?
Username: Thomas_g
NM
Post Number: 51
500 rms dual voice coil 2 ohm , ill wire the coilz in series so they match up to 4ohmz. But has ne body heard that amp does got any power or is it over rated?
Username: Goatin
U.S.A
Post Number: 319
Wire them like this and find a mono amp that puts out ~ 1000watt RMS at 2 ohms
you will have a hard time finding a amp that is 1000 at 4 ohm.
Username: Goatin
U.S.A
Post Number: 320
lanzar is a BIG NO NO!
Username: Goatin
U.S.A
Post Number: 322
If you are on a budget get this and wire it like I said
. http://ecoustics.shopping.com/xPF-Hifonics_BX1500D
Username: Greeney1888
Maple Grove, MN United States
Post Number: 99
also check ebay for hifonics amps (audiosavings)
Username: Thomas_g
NM
Post Number: 53
thanx dawg will it sound good?
Username: Cadillacdb
Houston , TX
Post Number: 531
Optidriven says Lanzar does its rated RMS but i havnt heard anyone else say this an ive also never seen any bench test sheets on um, but opti Swears by Lanzar, but he might only swear by them because its the type of amp he has ( he said hes seen bench test for them but he has never showed the bench test an ive never seen any myself so i cant recommend Lanzar )
this amp would be fine for two 4 ohms DVC type R's
http://ikesound.com/product-product_id/2424
or the hifonics BX1205D could be a good choice for a man on a tight budget or the one mitchell said which is the BX1500D ( its only about 20 bucks more then the 1205D an it will give you some head room )
any of those amps with the 4 ohm DVC Type R's would be a good choice
Houston , TX
Post Number: 532
the BX1500D would be a good choice but not wiring it the way mitchell said becasue it doesnt really do 1500rms at 1 ohm like it claims, it only really does 1350 at 1 ohm so probably around 880 at 2 ohms so if you got the BX1500D you would want to have the 4 ohms DVC type R so you could wire them together for 1 ohm mono an get about 1350 out of the amp at 14.4 Volts
