New member Username: PwcrowleyEvergreen, Colorado Usa Post Number: 1 Registered: Feb-06 | what type and how big of an amp should i get to push my jl w-0 15"? |
Gold Member Username: TjmutlowPost Number: 1423 Registered: Sep-05 | what voice coil config and ohm load |
New member Username: PwcrowleyEvergreen, Colorado Usa Post Number: 2 Registered: Feb-06 | this is all the info i have... Free Air Resonance (Fs): 19.2 Hz Electrical "Q" (Qes): 0.403 Mechanical "Q" (Qms): 11.29 Total Speaker "Q" (Qts): 0.389 0.405 Equiv. Compliance (Vas): 12.63 ft3 One-way, Linear Excursion: 0.340 in (Xmax)* 8.6 mm Efficiency (1W/1m)**: 89.8 dB Effective Piston Area (Sd): 130.2 in2 DC Resistance (Re)***: 3.97U Nominal Impedance: 4U Power Handling (continuous) : 150W Mounting Depth: 7 in Mounting Hole Diameter: 9 13.8125 in Driver Displacement: 3 0.110 ft3 and i know that its a single coil thanks for the help.. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5647 Registered: Jul-05 | how much can u spend |
New member Username: PwcrowleyEvergreen, Colorado Usa Post Number: 4 Registered: Feb-06 | hopefully less than 200 but i'd really like something that would make it sound hit as hard as possible without messing up my speaker |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5651 Registered: Jul-05 | Perfect http://www.ikesound.com/product-product_id/2469 |
