Two subs
why did i lose all radio reception when i hooked up two subs to my reciever?
Username: Project6
Post Number: 5742
Very good question!
And yet so ambiguously vague!
Username: Project6
Post Number: 5744
More info, please.
Username: Alphabet
Cape TownSouth Africa
Post Number: 51
Maybe you used the antenna to hook up the second sub?
On a more serious note, you will have to supply more detail if you would like a decent answer.
Username: Project6
Post Number: 5752
LOLUpload
dr thompson
ok,when i used a rca y adapter to the sub output on my amplifier,to hook up two subs i lost all radio reception.There is no problems with cd play though.only radio reception loss.
Username: Project6
Post Number: 5772
What happens if you only use 1 sub?
Does the sub has an output as well?
What kind of sub is it?
Dr. thompson
one sub is powered sony 12",the other is a jbl powered 10".I had the sony hooked up for years but added some small bose to my dining room so i needed xtra base in there.The sony just has one input,the jbl has two,which i have the adapter(monster)to use both L&R inputs.Like i said as soon as i turned on the reciever,i lost radio reception.I went back to one sub,and got reception back.Once again the cd's are fine(listening). thanks for your response,i wait to hear your advice.
Username: Frank_abela
Berkshire UK
Post Number: 1197
If you unplug the 2nd sub, does the radio reception return?
Weird one this...
Regards,
Frank.
Dr. Thompson
only if i unplug the rca connector and plug in the single sub chord to the recievers output.I'm using a sub chord with a signal arrow.(acoustic research)it has arrows on the chord showing you which end goes to the subwoofer.Could this signal type sub chord have something to do with it?Or am i thinking to much?..thankyou for your help.
Username: Stu_pitt
Irvington, New York USA
Post Number: 911
"...but added some small bose to my dining room so i needed xtra base in there."
I knew Bose sucked the life out of music, but this definately takes it to another level.
DR. Thompson
Or could i just get a antenna amplifier?Do they bother tv's if there close to each other?
Username: Project6
Post Number: 5815
I doubt that the directional arrows have anything to do with any of your reception problems.
Are you using any sort of antenna?
DR. Thompson
just the yamaha factory antenna,but that was all i needed.as cheap as the come,it worked fine.I plan to get a ant. amplifier tonite,but that doesn't tell me what happened.do you know if the ant. ampl. will cause interference with my tv? thankyou once again.
dr.thompson
guess we gave up on the DR. I may be able to heal,but this obsession with audio is getting the best of me!!!!!!!!!!!!!!!I just want my atari,those were the days.so simple............
