Hi. I have the 'dimmer' setting enabled but it seems to only control the OLED display itself. It seems to have no effect on the buttons nor the big center knob, each of which have bright blue LED backlights. They remain full brightness when the headlights are turned-on.
Is there a way to dim these buttons? They're awfully bright at night.
Jimmie
I should add that I do have the orange/white wire connected to the harness. I presume that's how the unit knows to dim the OLED display when the headlights are turned on. Doesn't seem to have any effect on the buttons, though.
