Kappa boxes
Username: Adgoodma
Boulder, CO United States
Post Number: 13
I have a new kappa perfect 12 still in the box.
I dont want to spend 100 to have cartoys build me a custom box or buy one for the same price from crutchfield...
Any suggestions on box building for first timers? Or should i just buy one?
Username: Greeney1888
Maple Grove, MN United States
Post Number: 44
build 1, it will cost you 12.00 for the MDF board and whatever else you need:
* glue or liquid nails
* screws
* silicone caulking
sealed or ported????
ill find some links for ya.. just a min
Username: Adgoodma
Post Number: 14
i wanna make it a sealed box. Better sound quality correct?
Plus the size of the box is extremely important, right.
I believe this box should be 1 cubic foot.
Post Number: 45
http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/reviews/20030701/build_box.html
theres one, idk what happend to my others
Username: Adgoodma
Post Number: 15
i want to make it sealed, better sq right?
also the size is extremely important right?
i believe this speaker needs one cubic foot
Username: Tjmutlow
Post Number: 1490
you can get a single 12 box 1cub ft for alot cheaper then that on ebay.
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 79
If you are gonna build one, member the displacement of the sub :-)
