More bass from 6x9s
Username: Cannonball
I have som sony xplode 6x9s in my car and i was wondering how I can get more bass out of them because I don't want to put subs in my trunk because I need the space.
Username: Alteraudiousa
Concord
Post Number: 231
get better speakers really. You could emphasize the bass on them but they dont do really good with the bass at high volumes.
"You could emphasize the bass on them"
What do you mean by that?
Username: Rovin
Trinidad & T...
Post Number: 5508
maybe u should run a pair of 8" subs free-air ......
Concord
Post Number: 242
most HU's have some sort of bass boost on them. Just up the gains on it.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11084
use an amplifier.. a head unit won't give the power you need to move the driver mass for decent bass response.
get some better high power 2-way 6x9s or look at some 6x9 woofers (no tweeter so all it does is bass/midbass) and those solutions together may eliminate the need for a sub if you're not too demanding about bass response.
otherwise you're going to have to relent and add something like a small bass tube.
you just can't get a lot of bass from speakers that aren't meant to function as subs in the first place.
