mattrox Unregistered guest | I am wonder what amp I should get to power my 2 10" sony xplod subs. They are 300w rms 4ohm dvc. http://www.walmart.com/catalog/product.do?dest=9999999997&product_id=4541644&sou rceid=0100000030660804302498 are the same ones. I'm trying to go for quality sound rather than just volume. I'm thinking of paralleling them to 2ohm and connecting them to an alpine mrp-m350 or mrd-m301. Thanks for your help. |
Silver Member Username: GoatinU.S.A Post Number: 274 Registered: Jan-06 | I dont mean to burst your bubble but sonys suck ! if you already have them take them back or sell them and get a Alpine R 12" that would be better than 2 10" xpold and it just a better made SQ sub than sony could dream. |
mattrox Unregistered guest | well i got 2 10" in a box for $50 so ill work the quality to the amp first then ill get better subs later i guess |
Silver Member Username: Matt12490Benicia, California Post Number: 394 Registered: May-05 | HAHA WALMART... HAHA SONYS... HAHA "I'm trying to go for quality sound" SONY SUCKS! if you're trying to stay cheap with your subs around $60 (which those sonys cost) you should buy 2 Resonant Engineering RE's from www.reaudio.com they cost $60 each for the 10" im pretty sure... will be louder and sound MUCH MUCH MUCH better than those sony's guaranteed. be smart. |
Bronze Member Username: JuliobSanto DomingoDominican Re... Post Number: 97 Registered: Dec-05 | 4 ohm DVC buy the directed 750d from ikesound and wire them to get 1 ohm load. Those subs are bad but that's your choice |
mattrox Unregistered guest | wiring 2 4ohm 300watt in parallell puts out 300watt @ 2ohm? or 600 watt @ 2ohm? |
Gold Member Username: RovinTrinidad & T... Post Number: 5533 Registered: Jul-05 | so u need an amp that does 600wrms @ 1ohm like Orion 600D ......... |
