steinkea Unregistered guest | I am wondering what subs would be good for a Profile AP1200 |
steinkea Unregistered guest | bump...!!!im fucked up...!! haha |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5446 Registered: Jul-05 | what are the specs on that??? |
steinkea Unregistered guest | » 600 W x 1 RMS bridged @ 4 ohms » 300 Wx 2 RMS @ 2 ohms » 200 W x 2 RMS @ 4 ohms » Features MOSFET circuitry » Dual Power Supplies » Power Light Strip » Built-in Low Pass Variable Crossover Network (50 - 250Hz) » Built-in High Pass Variable Crossover Network (80 - 1.2kHz) » Variable Bass Boost (0-12 dB) » Stable to 2 Ohms Stereo 4 Ohms Bridged » Tri-mode Operation » Low Level Inputs (RCA line-level) » Low level output (RCA line-level) » High Level Inputs (pre-amp level adapter included) » Wired bass level remote control (16.4ft) » Signal-to-Noise Ratio: 103 dB » Adjustable Input Sensitivity » Gold Plated RCA » Power and Speaker Ports » Dimensions: 15-1/4 x 2 x 10-1/4 (W x H x D) |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 5448 Registered: Jul-05 | 2 AA assasians 2 Infinty Kappa Perfects 2 Comp Vr's But whats ur budget |
steinkea Unregistered guest | I am trying to keep it as cheap as possible |
Steinkea Unregistered guest | how about this?? http://www.crutchfield.com/S-9jtUYNF7LQY/cgi-bin/ProdView.asp?g=510&id=features_ and_specs&i=028V123BP#Tab ....would this work and be loud?? |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 1839 Registered: Sep-04 | yuk. id definetly pick one of chauncys picks before that. me personally the AAs... or look at www.audioque.com the LW series. |
steinkea Unregistered guest | where can i get the AAs?? |
Silver Member Username: HomegrowncamWatauga, TX United States Post Number: 180 Registered: Jan-05 | www.ascendantaudio.com |
