Ok heres what happened: I was driving around with my stereo blasting. Then was gauges started goin crazy like the speedometer went up to like 100 and came down. And my battery light came down. I lowered my stereo and the car settled down. As went turn the stereo on the battery light kept flashin and the interior lights would dim like crazy. So, I turned the stereo off. So, I went home and turned the car off. Now, the car wont turn on. I tried charging the battery but no luck...it still wont turn on....anybody know wuts wrong? Any suggestion would be good....Thanks....sry its so long
i had a similiar problem like that happen to me few years ago. i didn't even have a system in my car. just a stock stereo. anyways, i took it to a shop and they told me my alternator was bad. they either fixed my alt or replaced it and it was fine. best thing for you to do is have a professional look at it.
well im going to have to load mine up on a trailer and drop it in a shop it suck lol sorry it wont let me type on my user name so i have post as anonymous my user name is Bret Harris
your battery is most likely still good, your problem is your alternator. Get a new h.o. alt. Put it on yourself and you will save alot of $$$$$. Do you know how to put a knew alt on?
depends on were you go.alternator and install will run around 300 to 400 range. Its not to hard to do it yourself. Get a high output alternator. If you do it yourself youll save 100 to 200 $.
