I bought a so-called pansat 2700, it is a clone one:in the machine it marked as "2700-N2". so I am wondering that how can I get the right BIN? Can I use the same one for original 2700A which named 140? Which cable do I have to use for programing, RS232C null modem cable or straight through cable? After the programing, is it the same process to perform setup as the 2700A original?
I am a new guy for FTA and i just read some info. so I sincerely need for your help. Thanks in advance.my pansat looks as
Help please.I have 2700A and it froze up so I JTAGed it.That went as planed but now instead of 8888 I have - - - - (4 greenlites) but will not take a new flash/bin.Any ideas or send for repair?? Thanks
They do NOT yet make bins for Pansat 2700 clones!...and U cannot use pansat 2500 clone bins!...U are screwed buddy!...I would use the 144 (released today) bin and the genuine pansat bins...and also learn how to Jtag it also...buy or make a jtag permanent cable..maybe U will get lucky and the genuine Pansat 2700 bins will be OK for U...but if not U will have a quick easy Jtag fix!
Aznviet
I have to same receiver as him and I was wondering after reading all that does the bin from the 2700A works for it?
