Is there any difference between the 3500S and 3500SD? It comes with a 128mb SD card. Is that the only difference? Anyone using the SD one yet? Can you buy an SD one and still use the serial port to load the bin? Is the bin for SD same as the 3500s?
Same bins for both...yes U can still cable/flash serial port bins with the SD...many are using the SD and love it,especially the SD card..card is only difference..
