What are the best 6x9 speakers? I know the kappas are the best, but what is almost as good? Are the pioneer 4 way 460w good for $70? The kappas are $140, and want speakers that are in the 70-90 range. This includes the kicker, RF, kenwoods too in that 70-90 range. Are any of there models better then the pioneer 5 way on an amp in a 6x9 sealed box?
lol...you're kidding right! Kappa's are not the best, not even in that price range. 175$ gets you a nice set of CDT CL-69x which are much better than the Kappas. I prefer those even over the Perfect components. I would look into Pioneer, Boston Acoustics or Polk. Infinity....please don't believe the hype, they're not that good.
No actually the Pioneer Rev series are the best out of Pioneer. Polk DB series is a solid all round speaker. BA has some very good speakers too. 5 way coaxs are a whole lot of stuff you don't need and a marketing gimic to make it sound better than it is. A solid 2 way or at most 3way coax is good.
I recommend the Infinity Referance 6x9's / Very smooth with good amount of bass. If you dont use a subwoofer then i whould go this route. Go with the 2 ways
Yeah, I have the kappa 3way 6x9's but they lack the tweet. I guess I will just keep these and hook up 2 tweets to the radio and buy a 2ch amp for the two kappas. They are great speakers, but lack the S's and T's tweet. Do you think 2 kappa 3ways to a 2ch amp in speaker boxes, will sound with 2 dome tweeters wired to the radio? Or it will in sound bad if I have just tweeters wired to the radio and the 2 kappas on the amp. I just have the 2 speakers and do not want anymore. whats the best way to wire 2 speakers and 2 tweets to a 2 ch amp or 4ch(if recommended instead? Thanks Brad
hey give the Alpine type R two-way 6x9 a listen it has really good midbass response.. very warm. a lot of people love alpine for 6x9s, myself included if that's the size you re stuck with.
