pertty much just something sealed casue i was told that to get a good response out of these subs sealed would be the best and ported would make it to boomy and losse more of its SQ ability
*grumble* displacement is not the determining factor where sq is concerned. the difference is whether you prefer a more punchy bass in the 12 over a deeper, more thorough bass of the 15. available power and space are what should be considered.
well i can get the power ... if i got the 12 id run a D5 1200.1 amp and if i got the 15's id run a d6 1500.1 amp ..... and i drive a 97 2dr blazer so i got some kinda room..... well its between the d6's and acedent audio's aresenals....
so should i go with the d6's.. i mean i have the front comps and rear fill already all diamond audio .... i need some ideas for subs now.... i donno what i should go with?
