Fortec lifetime ultra autoroll
dedrog
is there a autoroll for the flu yet? if so is it safe i currently have my flu programmed as a pantec with no autoroll and woulde like an autoroll if available.
Username: Lklives
Post Number: 596
NO..probably never will be...its a dying receiver..less and less software available..coders don't care about the Fortec anymore..
dedrog
thanks lk but from what i have now my reciever thinks it is a pantec so will it be possable to flash it as a pansat or leave it as a pantec and then a autoroll would work? or am i barkin g up the wrong tree
Username: Grimreeper
theres a resistor mod that can be done so you can load the clonesafe pansat autoroll but it still killing some receivers.be ready to jtag its kinda a trial and error thing
Username: Lklives
Post Number: 600
get rid of that receiver!..unless u like plain Russian roullette and spending all your time fixing and Jtagging the thing!
dedrog
thx for all your help not ready to chuck it yet but soon. With everything i have read everyone seems to like the pansat 3500 would this be a good reciever or will coders move away from this one to i don't want to buy junk anymore
right now the coolsat5000,viewsat extreme and the pansat3500 are the best out.theres the dreambox but way tomuch money
Username: Prfrmnj
Post Number: 55
The resistor mod for the older fortecs works great. OLDER FORTECS (614 Tuner)!!!!! Look in the old v. new thread LK posted earler. It is a simple mod and once done, you can load the Pansat 2500 271 bin and you'll have your autoroll. DON'T and I repeat DON'T forget to put a heat sink on the processor!!! I've done this mod on a few fortecs with different chip sets and it works fine. I have not tried it on a newer model (624 tuner), but it's said to work with them as well. That you'll have find out on your own.
