Bronze Member Username: CarajeanPost Number: 14 Registered: Jan-06 | Ok i blew my amp a while back and got help here to finally determine i did blow it. ok now i go the guy to replace the amp. he gave me a sinle channel mono block. so i hooked everything up. i twisted my 2 subs speaker wire together and stuck them in. ok i powered up my car and the subs and everything work its just there not as loud as before no where near as loud. now i want to know what just might be the problem this time. i did make sure the same wires were in the same place. |
Bronze Member Username: CarajeanPost Number: 15 Registered: Jan-06 | http://www.audioclubhouse.com/proddetail.php?prod=UL1600M&cat=247 my amp http://www.massiveaudio.com/lowband/products/subwoofers/performance/pw-12.html my subs i have two 12's. |
Gold Member Username: TjmutlowPost Number: 1441 Registered: Sep-05 | Sorry to say, that amp and those subs are really not compatable, you need a 1ohm mono amp, not a 2 ohm. if those subs are wired to a 1ohm load, your prob going to burn that amp up. the onlu way that would work is to run it at a 4ohm load and then you may only be seeing 150w to each sub. |
