Best receiver to buy
Username: Richsei
LK or Johny begood I hope you can tell me what you think is the best receiver to buy. it looks like a lot panset receivers are having alot of problems programing them.
I would like any help you can give me on this thanks
Username: Lklives
Post Number: 540
Pansat 3500....Coo*lsat 5000....Viewsat Extreme
adilson
Hay LK you once told me that the cool*sat is the best to have is that still true and is it as easy to program as the pansat2700a?
Buy DreamBox DM7020-S
Username: Erichu10
Los Angeles, California Usa
Post Number: 25
Best to buy receiver is either VIEWSAT Platinum/EX or C**lsat 5000. It cost less than $150
adilson
when buying a cool*sat5000 do i have to be on the look out for clones like when dealing with pansat?
i think LK is flip flopin like bush!
