What kind of box should I get?
Username: Dklotusjuggalo
Post Number: 33
I'm going to be running a Kicker 12" 2 ohm 800watt/425RMS sub. Should I get a closed box or a vented one? Which will be better for that low end bass?
Username: Mph
Post Number: 19
Depends on what type of music you listen to. Jazz, Pop, etc. like a sealed box and the resulting tight bass. Rap tends to favor a ported box for a more boomy sound. Sealed boxes have a greater overall power handling but ported boxes are more efficeint. All depends on personal taste. Tight or boomy bass is the bottom line.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11026
if they're solobarics, they only tend to work well in ported boxes.
sealed really doesn't work with those too well.
Username: B101
Queen City, NC USA
Post Number: 988
Kicker = Ported
=D
Username: Bass_4_da_deaf
Loudon, Tennessee America
go with a "vented" one. lots more bass. more air is moved, resutling in higher db's.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11102
well, really if you're after the highest SPL, use aeroports.
