Posted on Well ive tried nearlly every cd i have and it loads then says error 2...what does/is error 2 do or mean? Thanx in advance |
Gold Member Username: Tjmutlow
Post Number: 1352 Registered: Sep-05
Posted on what kind of radio? Try hitting the reset button, if that does not work, i would say the radio is bad. |
Gold Member Username: Illuminator
Post Number: 2626 Registered: Apr-05
Posted on Yeah, if the error codes consistently occur, there is definitely a problem with the headunit that needs to be serviced. |
Posted on Its an Audiowave acd 8005 and its brand new i got that when the cd player b4 was doing the same thing. |
Posted on bump |
Posted on plz can anyone help on this matter??? |
