Username: Suleman36 Maryland
U.S.A.
Post Number: 3016 Registered: Feb-05
Thursday, February 09, 2006 - 20:27 GMT Im running a ppi a600.2 for my component set up front and as you know it doesnt have crossovers so im using my HU to set the HPF to 12db @ 100hz Now for my subwoofer amp im using a crossfire vr1000d and i have the crossover set at 60-80hz lpf on the amp at 12db which is what the amp offers I also have my HU lpf set to 18db @ 80hz Am i setting this up right with the crossfire amp or should i just use the HU or AMP or BOTH ?
Username: N2audio Lawrence,
Ks
Post Number: 548 Registered: Mar-04
Thursday, February 09, 2006 - 22:09 GMT not exactly cut and dried http://www.carsound.com/cgi-bin/UBB_CGI/ultimatebb.cgi?ubb=get_topic;f=1;t=02002 6
U.S.A.
Post Number: 3019 Registered: Feb-05
Friday, February 10, 2006 - 06:35 GMT Link doesnt work.
Ks
Post Number: 554 Registered: Mar-04
Friday, February 10, 2006 - 06:53 GMT copy and paste it, and remove the space between the 2 and the 6 at the end. Don't know where that came from.
U.S.A.
Post Number: 3021 Registered: Feb-05
Friday, February 10, 2006 - 18:25 GMT Glasswolf, what do you say ?
Username: Glasswolf Wisteria,
Lane
Post Number: 11008 Registered: Dec-03
Friday, February 10, 2006 - 21:33 GMT be careful running two crossovers (amp and HU) since that can make the slopes cumulative. I'd stary with the HPF at 100 or 80Hz, 12dB, and the subs at 60 or 80Hz and a steeper slope like 18 or 24dB. then play with it from there and see what sounds best to your ears.
U.S.A.
Post Number: 3025 Registered: Feb-05
Saturday, February 11, 2006 - 00:10 GMT I guess in this case i will have to use my HU crossovers since my sub amp only has a 12db slope. My Premier 860 offers up to 18db slope for my lpf
