Jvc gz mc500
hello every bod i have a jvc gz mc500 camera its exelent cam but i dont know if it works as web cam
can any body help me please how is it work as web cam
thank you very much
Username: Project6
Post Number: 5458
what outputs does it have?
Have you read the manual?
salmi
yes i read manual but they didnt talk about it
Username: Project6
Post Number: 5465
What about the outputs?
salmi
USB
s-video/audio/video output
no firwire
Username: Project6
Post Number: 5466
What about a DV output?
salmi
sorry no DV output
Username: Project6
Post Number: 5489
What program will you be using for the webcam?
salmi
this is what i ask about
no driver on cd
the cd have only 3 programs:CyberLink PowerDirector Express , PowerDVD and Digital Photo Navigator 1.0
Username: Project6
Post Number: 5521
No...that's not what I meant.
Are you using the camera as web cam to have a video conversation with another person on another computer?
Or are you using it to capture video direct from your camera to the computer?
salmi
i can't use it as web cam i want to use it as web cam but i can't
now i using it to capture video from my camera
im asking how can i use it as web cam if u have idea
and thank you very much for u answers
Username: Project6
Post Number: 5526
first download MSN messenger or Yahoo messenger.
Do not connect the camera at all until the whole set up is complete and functioning.
After everything is done, log in to the messenger program.
Connect the camera via usb.
Turn on the camera.
Wait for the install to complete and load everything that the computer prompts.
Use the messenger program to configure your camera.
What operating system are you using by the way?
salmi
im using XP sp2
salmi
im using XP sp2
salmi
but my computer doesn't found my camera when i plug in
only found it when it on play mode when it on cam mode my pc dosn't found it
Username: Project6
Post Number: 5531
You are going to need a video capture card.
salmi
thank you very much Berny for u help and ur time
