2700a Bin File anyone?
Username: Sammy1
Hello,
I need the latest bin file for my new 2700a Pensat receiver. I would need the loader. Can someone be kind enough and E-Mail the files or at least give me the link?
mtlinphx@yahoo.com
Thanks!
Username: Lklives
Post Number: 560
Go to any DSS site and download them yourself!...LAZY!
Username: Sammy1
My friend there's a difference between being lazy and not knowing. Easier said than done when you know where to go... I've been searching for an hour and still no luck. A link would be greatly appreciated.
Username: Dannyboy88
hey LK how are ya i was wondering if you can answer this question for me i just got my dish a new bin file and i have pansat 2500 but in dish network when i go to add the codes for nagravision 2 there is only one key # and thats 00 and there isnt a 01 is there a way i can add one please answer if u can thank u LK
Username: Ajb
Post Number: 32
danial,when your see oo highlight that and press right arrow, should take you into 01
J pear sorry if it didnt sound clear but i already actually did that and it didnt change at all it just stayed to 00 and i went over to the right 0 and put in one to see if it would change but than i couldnt go back to 00 is there a way to add it do u know
Username: Ajb
Post Number: 33
daniel,scroll down to key number
scroll right 2times and you will then be in Nagravision2 mode and key 00
Enter the 00 there
then scroll back up to key number
then scroll right one more time to key 01
enter the key 01 there
then click okay to save
now click exit bytton 4 times and you should have tv.
would that also work for bell cause isnt bell
09-01 cause i have the same issue with bell in nagravision 2 i just get get the the 01 to enter the rest of the keys it just stays at 00 if u know Jpear thanx for helping me
Username: Ajb
Post Number: 34
daniel,
it will work.but why don't you just go to dssrookie.*om and get the latest bin for pansat2500 there.The latest bin has autoroll so you don't have to put the keys in manually.It will roll to the right key by itself.
Username: Ajb
Post Number: 35
i am sorry 2700 pansat files are there too.
Username: Kingyousuf
Post Number: 17
can i ge tthe DSS site so i can get it myself....
do i rename the file from ending with zip to bin?????
Username: Abj
yes you can. we can not post files here.
Post Number: 19
oh justice but Do I change file name ending with the zip to bin???????
Username: Abj
Post Number: 8
you don't change anything to the file.You can not change anything on the file.
Post Number: 21
but when i try to open the file via GT loader the bil file is clicked and i cant open that file.... so do i not rename the file (only zip to bin) the ending of the file???
the only way if i change the setting in GT loader to bin and app file then it works....
Username: Abj
Post Number: 9
you need to read more.You are supposed to use loader to load your file. Not GT loader.Go to dssrookie.com and go to pansat section.I don't think you have read what you suppose to have to load the program. I recommend you go to dssrooki.com.They will help you there.
Username: Lklives
Post Number: 582
Yousef...U know nothing of computers either...U have a VEEEEEEEEEEEERY LOOOOOOOOOng Road ahead!
.zip is a computer file...within a compressed .zip file, there could be 10 files....a.zip file is a "compressed" file to save space...U have to "uncompress" the .zip file to get at the files and folders within .zip file..the .bin file is compressed within the .zip file..same thing is true with .rar files..they are compressed just like .zip files..
Your computer needs a winzip or winrar program installed to unzip/uncompress the .zip or .rar files ..this is 5th grade computer 101 for 10 year olds..go to www.win-zip.com or www.win-rar.com and download the latest free version....win-rar will unzip/ uncompress .zip files as well as .rar files...so,which do U think U should use?
I think U have a better chance of being the next man on the moon, than U do with satelllite TV..
Username: Abj
Post Number: 10
if he's gonig to the moon than I'm going to venus,because there is alots of beautiful women
up there. At least thats what I heard. I wonder if that's true. What do you think, LK ?????
Post Number: 24
hi LK and Justice thanks so much
i have learned alot from reading those DSS rookie site and with your help i have fixed my problem.
The problem was i did not do a blind scan and did not unzio the 143 bin.
Thanks now i think i am getting better at this, will soon be a pro like you all.
Username: Abj
Post Number: 13
I am very happy for you. Now go watch some tv and be proud of yourself. I am glad things worked out for you.
