Is 4 AWG good enough for an RE 12.1 or should i use 2 AWG?
Username: Blainew
Post Number: 899
2 AWG or 4AWG
and is AWG the same as guage?
sorry if that is stupid..
Username: N2audio
Lawrence, Ks USA
Post Number: 552
awg = american wire gauge
4 is what I would recommend. If you have an unusually long run (15'+) you may benefit from going to 2 ga. Otherwise 4 should get it done.
Username: Blainew
Post Number: 900
thanks
